Hard to see how this project can be done on a shoestring budget if it's going to be installed in a service entrance panel. The approvals and certification process would be expensive in the US, Canada or EU, and I would guess in Australia too. Even inductive sensors on the wires leading into the service entrance panel would probably require approvals and certification. In most jurisdictions, the wires going into service entrance panels have to be in a conduit. So to install inductive sensors, the wires would have to be disconnected and pulled back, the conduit would have to be cut, an approved box installed for the sensors, then everything reconnected.
Many smart service entrance meters display voltage and current draw and have data output, usually IR or wireless. Not sure the average residential or small commercial power user would be that interested in power factor. For point-of-use measurements, there are a number of products on the market. I like the Kill-A-Watt EZ made by P3. It gives voltage, amps, watts, frequency, and power factor, but doesn't have data output connections. I've done limited testing of voltage, frequency and amperage on it with my bench instruments, and it appears to be accurate. Not sure if it's available outside the US, but similar products are. They're powered from the 120 or 240 VAC input.
So to do whole premises monitoring, approvals, certification and installation would be expensive. Point-of-use monitors already exist, but there may be an opportunity to develop the later with data output capabilities.
Mike in California
