They are reasonable for pulse operation, just will have a somewhat high ESR ( as part of the design, they are after all a wound coil of film with aluminium coating) and with the internal discharge resistor they will not hold charge for long. Great as power factor4 correction asa they do not shock you on unplugging, and will remove a lot of harmonics off the mains as well.
