Most likely a copy-and-paste error on the ebay seller's side. I assume some of these modules are made for a 3.3V supply, and other models for 5V.
It is not clear to me from your post which voltage (supply and logic levels) you actually intend to use. In either case, why don't you just buy a module from a vendor who states the voltage clearly and consistently?
The supply voltage needs to be a match in any case, of course. For the logic levels, driving 5V inputs with 3.3V output levels should work directly (since CMOS outputs should go close to 3.3V, and hence above the threshold for the 5V inputs). But you need to protect the 3.3V inputs from 5V output levels.
