I have a mid to late 80's Sony Triniton that only has an RF input. I have successfully injected composite video, and I have working audio injected right before the amplifier IC. The television is mono.
In order to have the volume control function correctly, would a voltage controlled resistor be the best solution here? The volume control voltage increases when the volume is turned up.
