Hi everyone! A friend of mine built a wood chipper running of a 2HP 3 phase motor, but the inicial torque is too much for the axis and it might break. We want to reduce the inicial torque, just to start spinning the axis, and then apply the normal power. He has a vfd that would be great for this, but it its only single phase. We thought on modify the motor to run on single phase and then connect it to the vfd, but since we are modifying it, we could also had a starting capacitor and a running capacitor. However, i dont know the capacitor value that i should use, i tried 30uf and it was too low to start. After doing some research i found the the appropriate value is around 140uf to start and 20 to run. Is this correct? is there another way to do it?
Thanks!
