you all have detail understanding about dds and all about filtering stuff,can you help me by suggesting output circuit to get precise output
Sorry OP, it's turned into one of those threads ...
It's been a while since I looked or thought about it, but I don't think you're going to find a a drop-in example for you to copy. In reality, it's not that easy to solve in a way that makes it worthwhile (e.g. low distortion, stable & flat from near DC->15/20/30MHz, etc) at the price / performance required. There's several reasons cheap DDS-based signal generators tend to top out at 2/5/10 MHz - and that's one of them.
If you Google around, you'll stumble across the circuit shown
in this thread - it was originally designed by PA3CKR for
his DDS signal generator project, and IIRC is pretty much pieced together straight from TI appnotes. Supposedly it's good for 40MHz, but at those frequencies you're in an area where layout & construction matters just as much as choice of device - it's not a job for an amateur unless they plan on learning a lot.
Personally I'd look at something like the Analog Devices AD600 / AD602 for the basis of the AGC stage - from memory, the datasheet of one or the other has a nice-looking 2-stage AGC example that should be suitable. From there, I'd be looking at high-frequency line driver amps from the likes of TI as an output stage.
