The actual inductance is not only depending on the length of tha cable, but also on the loop size. Two separate wires will have higher inductance than a cable where the individual wires are kept together by the insulating jacket.
Sine shaped, damped oscillation at power on. Almost the same will happen with a DC step on the input with a ceramic capacitor. (Linear has an interesting appnote on this, google MLCC Linear). Compare it to a stepup regulator, where the wire is the coil and the capacitor is the switch transistor. At power on the capacitor is empty, which equals a closed switch. As the voltage over the capacitor reaches the input voltage, the switch "opens". V=L×di/dt
You would like to have a capacitor between L and N for filtering and protection of your regulator. To change the di/dt you can add a series resistor between L and the filter capacitor. The regulator sits in parallel with the C, but the 230 Vac sees an RC. The addition of a series resistor was mentioned earlier in this thread.
