Thanks, We cannot add anything on the PCB itself , as there's no room.
We can only add stuff to the live and neutral wires that connect to the product. –Hence the X2 capacitor we added, as described in the top post.
The "500v peak" scope shot in the top post was with a 100nF X2 capacitor connected between live and neutral. There was also 25uH (10 metres) of coiled up mains cable ahead of that so that we could simulate line inductance.
When we changed the coiled up cable to 100metres of (coiled up) length, then the voltage peak goes up to 550V (as attached)…..youch! (100m of mains cable had an inductance of 73uH )
Obviously, the more “line inductance” we add, the higher the peak voltage to the LR8 is going to go….youch again!
So, the attached 550v peak scope shot is with 73uH of mains cable and then a 100nf x2 capacitor, then the product
We are wondering what is the typical maximum line inductance in the installation that our lamp will see?
It’s a lamp that gets put in pub gardens, outdoors.
