Do you know the currents of the windings? My guess is that the 51V will be several amps at least, but the 18-0-18 could be only 1/2 an amp.
For a linear power supply, it would be better to have more taps in the 51-0-51 windings unless you want to make a high voltage supply at a limited amperage - like 0-120V at 1 A.
