Oh, you must mean a gas discharge shunt regulator? If they contain radioactive material, it's usually something like nickel (which does decay relatively quickly; radium itself takes millenia to decay), which serves to reduce the ignition voltage. The arc voltage is more or less unaffected. If it is glowing (and at the correct color, if you're familiar with the characteristic color of that type of tube), it's fine.
