For motor control, you'll be running your d/q axis current control function locked into the fundamental PWM loop. Because you'll want to change the phase voltage modulation at every opportunity. If you run too fast, you won't be able to fit your control code into the time available and hence you now will have several PWM cycles with the same modulation, which defeats a lot of the purpose of running faster!
For pretty much all practical motors, using centre aligned pwm, with it's intrinsic frequency doubling, means that the ripple currents will already be very small at most sensible fundamental pwm frequencies (8 to 20 khz). Of course, if you are driving some sort of ultra-trick, ultra low inductance high speed eMachine then sure, start ramping the frequencies up.
And of course, honorable mention here to EMC compliance? IS it required, to what level? The faster you switch, the bigger head-ache it becomes. Or if you switch slowly, then your deadtime becomes a larger proportion of your modulation index.
