Hi all,im putting together a psu using a 723,im using this schematic,the iss use a lower value sense resistorue i have is,i want the current feed back to work from about 100ma upwards,the issue i have is to get 600mv from the current sense resistor,it has to be a high value to produce 600mv across it for 723,this lowers the output to much overall,is it possible to amplify the sense voltage to feed the 723 cl and cl pins,therefor use a lower value sense resistor,ive thought of using a sg3532 but they are expensive!,cheers m3vuv.
