Tip for mixing small amounts of epoxy... save the q-tips/sticks. A small chisel or razor blade over end grain cutting board (or glass if you don't mind dulling a chisel/blade). Spread it out into a long thin, sub micron thin smear. Then scoop it up perpendicular to the smear, picking up just small bit of the smear at a time, stacking each layer of poorly mixed, streaky epoxy next to each other on the blade. Now you have lots and lots of streaks in a stackup blob, like layers of damascus. Spread this out again, into the long smear, mixing all these layers into each other. 3 or 4 repetitions will make a perfect mix, and you don't waste any epoxy. Just pick it up a little bit at a time to make a big fat blob on just the side of the chisel, use it, and wipe the blade with a paper towel when you're done.
It's not uncommon I use all the epoxy I mixed. Or maybe I run out and have to mix up a tiny little bit more. I stretched one tube of JB weld for a decade. The caps had fallen apart, and I was closing the tubes with a piece of plastic tied over with a string, lol.
