Author Topic: A hearing Aid Amplifier  (Read 6752 times)
Offline Md Mubdiul Hasan
  • Country: kr
  • Lets learn more to be more inspired in Electronics
« on: December 20, 2016, 05:20:31 PM »
Hello Everyone,
Let me introduce one of my project what I worked through 6 years back with a professor.
Still it need to be more efficient.
Its a low cost hearing aid amplifier using LM324 as a main Op-amp.
We were trying to apply 3 frequency selecting gain circuits, 1. Bass Control 2. Mid frequency 3. Treble control.
I did apply some model from online for having suitable gain at human  sensor range like 2-3KHz.
 Take a look in this attachment, sorry for its hand drawing circuit.
I need you valuable suggestions. :-+
Hasan
Offline Hero999
Re: A hearing Aid Amplifier
« Reply #1 on: December 20, 2016, 08:08:57 PM »
The first and possibly the most easiest thing you could do to improve it is to use a better op-amp. One which doesn't have the horrible crossover distortion the LM324 does. There are plenty of better op-amps in a similar price bracket which have a class AB output stage and minimal crossover distortion.
TL064
http://www.ti.com/lit/ds/symlink/tl064.pdf
TL074
http://www.ti.com/lit/ds/symlink/tl074.pdf
TL084
http://www.ti.com/lit/ds/symlink/tl084.pdf
MC34074
https://www.onsemi.com/pub/Collateral/MC34071-D.PDF
MC33078/ MC33079
http://docs-europe.electrocomponents.com/webdocs/11a6/0900766b811a6561.pdf
MC3403, MC3303
http://docs-europe.electrocomponents.com/webdocs/12e1/0900766b812e1cf7.pdf
« Last Edit: December 20, 2016, 08:31:22 PM by Hero999 »
The following users thanked this post: cdev, Md Mubdiul Hasan
Offline Rerouter
« Reply #2 on: December 20, 2016, 09:16:26 PM »
I went ahead and remade it in a little simulation tool so you can have a play around,
Defiantly agree the LM324 is a rubbish op amp in general,
I labeled the potentiometers on the right hand columb as i understood there function to be based on the output waveform, to me it seems that 2 of them don't significantly alter it in a way i can grasp?
http://tinyurl.com/gt3p3vs
And the full link below for people trawling through in years to come.
http://www.falstad.com/circuit/circuitjs.html?cct=$+1+0.000005+9.001713130052181+50+5+43%0Ar+160+288+160+192+0+10000%0AR+160+192+160+144+0+0+40+9+0+0+0.5%0Ac+160+288+256+288+0+1.0000000000000001e-7+0.795344360852607%0Ar+256+288+256+368+0+33000%0Ag+256+368+256+384+0%0Aa+320+304+416+304+1+9+-9+1000000+0.6901185446271082+0.6901254458125545%0Aw+256+288+320+288+0%0Aw+320+320+320+352+0%0Aw+320+352+416+352+0%0Aw+416+352+416+304+0%0Aa+592+384+688+384+0+9+-9+1000000+0.000007269126774086928+0%0Ag+592+400+592+416+0%0Aw+544+368+592+368+0%0Ar+912+384+976+384+0+10000%0Ar+1008+384+1072+384+0+10000%0Ar+992+320+992+384+0+100000%0Ac+544+368+544+304+0+1e-8+0.37088856890630256%0Ac+480+304+480+368+0+1e-8+0.3340798978713451%0Ar+544+304+624+304+0+6800%0Aw+688+384+688+304+0%0A174+480+304+544+336+0+1000000+0.8069000000000001+Bass+Amplitude%0Aw+512+336+512+368+0%0Aw+512+368+544+368+0%0Aw+480+368+512+368+0%0Ar+480+304+416+304+0+6800%0Aw+624+304+688+304+0%0Ac+864+208+928+208+0+1e-8+0.19857312609201755%0Ar+928+240+864+240+0+15000%0Ag+864+240+864+256+0%0Aa+992+304+1088+304+1+9+-9+1000000+-0.19853866235959614+-0.19857312609201755%0Ag+896+336+896+352+0%0A174+864+320+928+336+0+47000+0.797+Volume?%0Aw+976+384+992+384+0%0Aw+992+384+1008+384+0%0Aw+1072+384+1088+384+0%0Aw+1088+384+1088+304+0%0Ar+992+288+928+288+0+100000%0Ar+864+288+800+288+0+15000%0Ac+864+288+928+288+0+1e-8+-0.025256513211524223%0Aw+912+384+768+384+0%0A174+768+320+800+256+0+47000+0.0743+Upper+Attenuation%0Aw+864+208+864+240+0%0Aw+928+208+928+240+0%0Aw+928+240+928+288+0%0Aw+768+320+768+384+0%0Aw+768+384+688+384+0%0Ar+160+288+96+288+0+1000%0Ar+992+320+928+320+0+1500%0A170+96+288+48+288+2+20+4000+1+0.1%0Ar+1120+304+1184+304+0+10000%0Ar+1248+304+1312+304+0+10000%0A174+1184+304+1248+336+0+470000+0.30200000000000005+Upper+Amplitude%0Ac+1216+336+1216+368+0+1e-9+0.0023661890669046215%0Ar+1184+368+1120+368+0+100000%0Ar+1312+368+1248+368+0+100000%0Aw+1312+368+1312+304+0%0Aw+1248+368+1216+368+0%0Aw+1216+368+1184+368+0%0Aw+1120+368+1120+304+0%0Aa+1216+416+1312+416+0+9+-9+1000000+-0.00004411731887452016+0%0Aw+1216+400+1216+368+0%0Aw+1312+416+1312+368+0%0Ag+1216+432+1216+448+0%0Aw+1120+304+1088+304+0%0Ao+61+64+0+2083+10+0.000390625+0+-1+0%0A
Offline Kleinstein
« Reply #3 on: December 20, 2016, 10:44:50 PM »
There are better OPs around - even the list below is more like the old ones you found 20 years ago. Likely one would use a lower voltage (e.g. 3xAA = 3.6-4.8 V). The resistors are all quite low - for low power something like 10 times the value should be OK.
  • Country: kr
« Reply #4 on: December 21, 2016, 12:56:02 PM »
Dear Sir Hero999,
Your first 3 op-amps are available in my sock.
Lets study those datasheet carefully and figure out what feasibility I could get.
Kindly suggest me to improve the design.
« Last Edit: December 21, 2016, 01:26:03 PM by Md Mubdiul Hasan »
Hasan
  • Country: kr
« Reply #5 on: December 21, 2016, 01:15:19 PM »
Dear Sir Rerouter,
You have made the things easy! :)
Thank you very much.
Having with this nice simulation, lets talk about more what I did in past.
At the same time I will concentrate your simulation.
Could you explain please more?
I have been separated all  3 circuit parts and feeding with a signal generator.
Take a look my previous graph in this post attachment.
Bass and treble control was  working may be.
Changing POTs position and capacitor values, I saw system.
Can you make comment about +9v and -9v.
I was thinking, to take it in pocket.
« Last Edit: December 21, 2016, 01:31:34 PM by Md Mubdiul Hasan »
Hasan
  • Country: kr
« Reply #6 on: December 21, 2016, 01:21:17 PM »
Dear Sir Kleinstein,
Could you suggest any in this range ?
Moreover, any MCU which can work all together?
Suggest me any design/manual/reference.
Regards
Hasan
Hasan
Offline Audioguru
« Reply #7 on: December 21, 2016, 03:59:24 PM »
I am 71 years old and have normal hearing loss of high frequencies for my age (about -40dB at 8kHz). I could not make hearing aids as small and with as many features as my new hearing aids that are made in Switzerland. My hearing is fine below about 250Hz so vents in the earmolds allow low frequencies to pass then the transducers in each earmold produce the boosted high frequencies. The hearing aids communicate settings, features and programming between them with Bluetooth. If I hold a phone to one ear the hearing aid in that ear detects it and feeds the sounds to both ears. The microphones are front, back, left and right. Most settings have the directionality aiming at speech in one direction. One setting has higher than normal gain. Another setting has automatic fading of background noise. Most settings have AGC but another setting is wideband with not much AGC for music. They produce no electronic noise and never any overload distortion. I am very glad to have them.
Here are graphs of normal hearing loss for men and women at different ages:
The following users thanked this post: salbayeng, Md Mubdiul Hasan
  • Country: kr
« Reply #8 on: December 21, 2016, 05:19:45 PM »
Dear Sir Audioguru,
Thank you to receive my post.
I am so lucky to have your comment here! :clap:
I raised my hand to make one circuit for my country where people cant buy expensive one!
What difficulties you faced during research?
What kind of transducers you have used?
Did you make MCU firmware ? Which MCU you have been use?
You might  talking about an advanced one. Position sensor can be used in this case. Was it speech controlled ? with proper DSP?
I saw many unwanted signal accumulated from background with this simple circuit, something like antenna is collecting things. Kindly, put your valuable suggestion about develop this circuit.
Thank you,.
Regards
Hasan
Offline salbayeng
« Reply #9 on: December 21, 2016, 05:34:54 PM »
You can combine all the tone controls in one stage,  using baxandall type circuits
eg from here http://www.electro-tech-online.com/threads/baxandall-analysis.129124/
I'm not sure you need a midrange control?  Hearing aids have a fairly limited frequency range (not as much as 100Hz to 10kHz) so you could squash together the bass and treble cutoffs.
http://www.learnabout-electronics.org/Amplifiers/amplifiers42.php
The following users thanked this post: Md Mubdiul Hasan
  • Country: kr
« Reply #10 on: December 21, 2016, 07:50:28 PM »
Dear Sir salbayeng,
So kind of you!  :-+
Its a good circuit indeed.
Let me show you what previous circuit I have used. :popcorn:
Lets compare them.
Thank you.
« Last Edit: December 21, 2016, 07:56:08 PM by Md Mubdiul Hasan »
Hasan
Offline salbayeng
« Reply #11 on: December 21, 2016, 08:05:58 PM »
Looks to be nearly identical, your schematic is designed for single supply operation, as it has a rail splitter (R11,R12).
  • Country: kr
« Reply #12 on: December 22, 2016, 12:32:49 PM »
Dear Sir salbayeng,
Dont you think, depending on Op-amp, power supply should choose ?
Whats the benefit of -Ve and +Ve ? Does not it amplifying signal on both side?
What are the drawback of single supply ?
My main circuit at first post, if you can see my supervisor suggest me to keep the cascaded 3 equalizer in in series !
That means signal from microphone with certain frequency could trapped in one frequency selected portion.
In this time we observed both boost and buck operation gain.
Dont you think its a wrong idea as background noise could directly  appear  to the post amplifier for hearing ? or gains are multiplied ?
If you take a look on your circuit, one portion of equalizer directly connected  to the output, having in parallel action.
In the Bass control section, R8 is connected other Mid and Trable  are connected with capacitors.
Make sense ! Frequency is inversely proportional to capacitor impedance.
During operation, one impedance is active while inactivate others.
Those make huge change on gain.
Let me think it more, because I need a noiseless and distortion free like others.
Well, did you see senior member Audioguru says what in this text? look at his graph.
Keep in touch.
I need your help.
Hasan
Offline WonderWheeler
« Reply #13 on: December 24, 2016, 03:09:56 PM »
Am 63 years old myself and am somewhat hard of hearing, probably the result of noise in the workplace etc. The thing I am missing most is the treble or high part of the spectrum. I understand that is common with men. For that reason, women with higher frequency voices are harder to understand. I need to boost the high part to make out consenents, the different sounds of "c" or "s" or "t" is hard to differentiate, and all sound the same to me.
I have been looking at Amazon and such for some cheap pocket sized units and noticed some things to look out for. The cheapest ones don't have a switch to boost , high frequency or to cut out low frequency (noise).
Some have directions that say to unplug the earphone before you turn it on or you blow your ears out, lol. Watch out for that.
Another one used a mono earphone socket to save a few cents, even though stereo sockets are available. It meant that if you plugged in a typical stereo headphone you would hear out of only one earpiece, lol. The recommended purchase of an adapter for 5 usd to change the mono signal to stereo.
One cheap one has a built in fm radio. Although you couldn't use both features at once.
One cheap one was a hearing aid in one position then in the other setting had in some kind of weird Chinese concept would send a signal to your earlobe with a conductive clip acting as an electrode as a quack cure for tinnitus. Through some kind of acupuncture idea.
For me the ideal unit would work with an fm radio, could get distant stations maybe some kind of short antenna, would have an oversized battery like maybe AA, would automatically turn itself off if not being used, boost high frequency sound, and be used kind of like an mp3 player.
Something like this perhaps http://www.banggood.com/E-8-Rechargeable-Hearing-Aid-Sound-Amplifier-for-Two-Ears-Use-FM-Radio-p-1024136.html?rmmds=mywishlist
or this http://www.banggood.com/V-99-Hearing-Aid-Sound-Amplifier-Portable-Divice-Black-p-1018275.html?rmmds=search
or this https://www.amazon.com/Pocketalker-Ultra-with-Rear-Wear-Headphones/dp/B00I5PX5C2/ref=sr_1_3?s=aht&ie=UTF8&qid=1482553666&sr=1-3&keywords=pockettalker+ultra
for a bit of a laugh, check this one out http://www.banggood.com/Electric-Tinnitus-Treatment-Instrument-Ear-Hearing-Repair-Device-p-949288.html?rmmds=search
sorry for the long post, just trying to compare ideas
« Last Edit: December 24, 2016, 03:33:53 PM by WonderWheeler »
« Reply #14 on: December 24, 2016, 03:37:27 PM »
I was even looking at raspberry pi and bat detectors for ideas on how to make a personal hearing aid.
Offline salbayeng
« Reply #15 on: December 24, 2016, 03:45:44 PM »
Hi WonderWheeler , welcome to the forum ;D!
Is that a blessing or a curse?  Perhaps a  reward  for putting up with the screeching for all those decades!
I'm barely 4 years behind you! but my hearing is still good, (apart from some selective deafness touch wood!.
BTW if you want to do a partial quote as I did above press the button left of the ebay button and then
[quo te]  cut_n_paste_text_here [/quo te]
(you need to remove the space in "quo te")
or just highlight some text and press the button.
The following users thanked this post: Md Mubdiul Hasan, WonderWheeler
Offline salbayeng
« Reply #16 on: December 24, 2016, 03:53:38 PM »
re
There are quite a few simple schematics on the webs using "jelly bean" transistors google hearing aid schematics .
Have you thought of getting an old style transistor radio , cutting the track going to the volume control and dropping in a electret microphone?
Offline salbayeng
« Reply #17 on: December 24, 2016, 04:39:17 PM »
Something like this......
This uses the electret standoff voltage to bias the transistor, this might need tweeking (by changing VR2 and R3 together , note that R3 should be 1/10 of VR2 , and C1 goes up as R3+Vr2 go down)
The base of Q1 should be ~ 2/3 of VCC  (if transitor saturates then tap the base in halfway along R4)
  • Country: kr
« Reply #18 on: December 26, 2016, 01:18:07 PM »
Dear Sir WonderWheeler,
My all respects goes to you. :)
Thank you a lot to participate in this post :-+.
Its seems like I need to consider suitable cases while make a  Hearing Aid.
You mean you cant recognize the different tone of sound?
That means your hearing aid  need to be  consistent at higher frequency gain.
I have been looking at Amazon and such for some cheap pocket sized units and noticed some things to look out for. The cheapest ones don't have a switch to boost , high frequency or to cut out low frequency (noise).Some have directions that say to unplug the earphone before you turn it on or you blow your ears out, lol. Watch out for that.
Can you realize why the manufacturer suggest you to unplug the earphone before you wear it?  Cheapest one can suppress noise from circuits and environment/background?
I see, did you open the plastic cover and saw how is the circuit ? Kindly give me some idea or reference.
This one is multipurpose, lets think about only hearing aid.
Does the  conductive clip has any communication with a device ?
Well said, it can be an experiment, but it might need transmitter or receiver  to collect signals from medium.
OKay, let me know which version of raspberry pi and detectors you have use? If we want to make a cheaper Hearing aid, will it be cost effective using  raspberry pi?
Hope you will response .
Regards
Hasan
  • Country: kr
« Reply #19 on: December 26, 2016, 01:43:08 PM »
Dear Sir salbayeng,
You looks a professional engineer for sure! :clap:
Let me understand your simulation circuit and graph.
Seems like you are playing with a bjt PNP in CC mode, trying to boosting up the gain of input AC signals putting in base.
Which simulation software you use ?SIMetrix?
I would say, its a good practice to look at the gain over a frequency BW.
Hasan
  • Country: kr
« Reply #20 on: December 26, 2016, 01:46:07 PM »
Ok fine. Let me try in this way.
I am usng LTspice and multisim.
Hasan
Offline Audioguru
« Reply #21 on: December 26, 2016, 02:22:08 PM »
Designing a very complicated circuit, making it very small, finding very small transducers and using a tiny battery.
My transducers are about 2mm diameter and 5mm long and are inserted into the earmolds that are in my ear canals. The actual hearing aids are placed over the ears and are about 18mm long, 5mm high and 3mm thick. The batteries are one tiny button cell #312 (1.45V zinc-air) in each hearing aid and are replaced every 8 days (they are turned off each night). The hearing aids beep or say "low baddery".
I tried a demo of Widex brand hearing aids but I did not like their sound, I tried then bought Phonak brand hearing aids. The hearing tests were free and the demos were free for 30 days each.
Yes the hearing aids are advanced and are digital, not analog.
Your circuit is a simple "eavesdropper amplifier" using noisy distorted old opamps and a simple tone controls circuit. Maybe you built it on a solderless breadboard and all the wires and rows of contacts are antennas that pickup hum and other interference.
My hearing aids are programmed to produce wideband and wide level sounds when in the "music" mode. They sound so natural that I forget I have them on.
Cheap old circuits do not produce enough high frequency boost (mine have +40dB which is 100 times more signal level but a simple tone controls is only +10dB (only 3.2 times more signal level).
Hearing aids are expensive and the audiologists who program them are highly paid skilled professionals. Before I retired I made enough money working to buy everything I wanted and more for investments. The interest on my investments pays for my expenses now. Also my government is paying me a pension. My government paid for a portion of the cost of my hearing aids. My government also paid for a portion of the cost of deluxe lenses in my eyes when I had cataracts surgery and completely paid for my heart attack surgery so now I am young again.
« Last Edit: December 26, 2016, 02:34:20 PM by Audioguru »
  • Country: kr
« Reply #22 on: December 26, 2016, 04:41:35 PM »
Could you kindly suggest me a design that I can workout for better result. I know advanced design patents are always hidden and should have business policy. Just to make my work as "getting started"
For such tinny design component, what kind of amplifier you have use? Are you talking about built in amplifier with low noise, distortion free ICs? Its very small size battery, isnt it? Are not you talking about mini or micro scale ! Did you work with energy harvesting circuits?
I was talking about micro-controller code, you might be talking about end-user software like Android.
Yes, it could be.
I am also thinking that things must be programmed where you could have perfect gain level in different frequencies.
Very significant information, I also believe that in practical result,  LM324, OPA 07/06 will not give a proper answer.
Was that mission successful ? Dont you mean it needs a huge investment, time , research and manpower?
If its in Canada, for-sure government will support a lot. Come up with a newer idea in a non-productive environment is time consuming to overcome!
Hasan
Offline Audioguru
« Reply #23 on: December 27, 2016, 02:47:55 AM »
Instead of making a hearing aid circuit and letting the deaf person fiddle with its controls, the deaf person should have a proper hearing test by an audiologist (my tests were free) to accurately determine the loss frequencies and how much loss. Then the hearing aid should be carefully adjusted by an audiologist to eliminate the losses.
My hearing aids came adjusted for severe high frequency loss with a feature where the highest octave from 10kHz to 20kHz was shifted down to 5kHz to 10kHz but I did not like how that sounded so it was eliminated and the highest frequencies were boosted as much as is possible. Now the sound is natural.
I did not like the anti-feedback program that caused continuous high frequency tones or beeps to flutter so in the Music Mode it was turned off and sometimes there is high frequency feedback.
I asked for one Mode to have very high sensitivity which is useful and playful. Then at a conference I can clearly hear what a far away person is mumbling but most people cannot hear him. I was walking in the mall with the hearing aids set to the Very Sensitive Mode and I heard a woman behind me call my name. I turned around and nobody was there but there was a woman far away on the phone talking to somebody that has my name. ::)
The directionality of the four microphones (left, right, front and back) reduces background noises but sometimes they switch oddly. I was talking with my wife in front of me and when she paused the microphones switched to somebody talking behind me. When my wife began talking again then the hearing aids had to think about switching back to her or not which caused a delay.
I am a new grandfather. When my grandson cries I switch the hearing aids to the Muted Mode to reduce his loud cries and the same when my dog barks when there is somebody at the door. When the hearing aids are muted then I cannot hear my wife scold me. ;)
Since the transducers are tiny then their sound hole becomes plugged with normal ear wax. The hearing aids have a replaceable filter covering the hole which I change when I replace the battery cell.
  • Country: kr
« Reply #24 on: December 29, 2016, 06:58:08 PM »
What instrument did audiologist  used to clarify your hearing loss? I mean to understand your hearing loss.
Yes, looks an abnormal range, my professor was considering 2-3kHz.
Which feedback you are talking about?
:=\ wasn't  it a confusion? Perhaps strong sensitivity of your device ! or your unconscious  mind ?
I see, real deaf person could feel it. Let me check how much I have lost !
I am also like your grandson, but I have figure-out that your writing has sharpness, no matter your ears!
I saw the companies website you recommended, seems like they have technically sound research engineer and resources. People here in South Korea also trying to  make things more tinny with energy harvesting idea. All things we are talking about can be combined in a single chip. I have been working on ECG device under a PhD lab, I saw they use only a IC to cover everything!
Hasan
Offline Audioguru
« Reply #25 on: December 30, 2016, 04:00:08 AM »
In a soundproofed booth I was given in-the-ear headphones and various frequency (250Hz to 16kHz) tones at different levels were played. Some tones warbled their frequency so that they sound different to steady tinnitus sounds. I pressed a button when I heard each tone.Then words were played and I was to verbally repeat them. Then words with background noise were played with the background noise increasing and I was to verbally repeat them.
Old people lose hearing sensitivity to all high frequencies but most loss is from 10kHz to 20kHz. Look at the graph I posted. Since a hearing aid has difficulty producing high frequencies loud enough then a standard system is to play high frequencies one octave lower. People exposed to loud noise or gun blasts for long durations become deaf to many frequencies, 2kHz to 3khz is the most common.
Telephones and AM radios do not play frequencies higher than 3khz but the important consonants sounds in English speech go to 14kHz or higher and without them then speech in not understood.
Acoustical feedback when the mic can hear the earphone and the sound goes around and around. The gain at high frequencies of my hearing aids is 40dB (100 times) or more so the standard anti-feedback system in the hearing aids was usually used to eliminate the feedback (high frequency squealing if an earplug becomes loose or if a sound reflecting window or something is close to a hearing aid). The anti-feedback system causes high sound frequencies to flutter that makes music or the beeps from my test equipment sound bad. Some cheap anti-feedback systems simply cut all high frequencies that is a very poor way to do it.
The high sensitivity Mode has very high gain so that somebody talking far away sounds loud and clear like they are near me One directional microphone picks up a distant sound but the other mics reject and cancel background noises from other directions.
I did not know that I had a serious high frequency hearing loss since it occurred very slowly over the years and I did not know that all older people lose high frequency hearing sensitivity. I always protected my hearing from loud noises so I thought my hearing was still good.
The Chinese website Banggood has the cheapest and poorest quality "hearing aid" I have ever seen. I watched South Korea Goldstar company grow up and become LG Electronics (Lucky Goldstar) and South Korea Samsung company grow up. Maybe they made high quality hearing aids.
The following users thanked this post: WonderWheeler
  • Country: kr
« Reply #26 on: December 30, 2016, 04:28:44 PM »
I see, these  booth are  available in any ENT medical center?
If so, then what amplifier system you prefer?  If we need boosted gain in high frequency, what should be the basic IC ? Can you suggest any company like TI,AD,Linear, ST?
or, you suggest raspibary pi?
People exposed to loud noise or gun blasts for long duration become deaf to many frequencies, 2kHz to 3khz is the most common.
Dont you think, I need a survey at my won country considering in-general deaf people?. Yes, I do believe your graph.
But from your experience, it looks critical deaf person need special hearing aid.
Let me know, which way(circuit system) you feel  it poor and inadequate  capabilities.
Then which point you think, need to be work in this case ? In what device you find this information?
Yes I heard so, I am working in this country as an Engineer but my mother land in Bangladesh. I am thinking about my poor people who need a cheaper one, I know china get priority in our market, but no trend has been build up internally who can make circuits,pcb patent along with good research activities.
Hasan
Offline Audioguru
« Reply #27 on: December 31, 2016, 07:45:04 AM »
The soundproof booth used for hearing tests is available at every hearing aid clinic. In my small city there are about 15 hearing aid clinics. I had free hearing tests at 3 of them.
My hearing aids are digital but they must use some analog circuits in their custom made IC. I do not know any opamp that can be powered from only 1.45V at an extremely low current like my hearing aids.
Since all old people lose high frequency hearing sensitivity then they all need hearing aids programmed to eliminate their loss after a proper hearing test but many old people do not care about hearing sounds properly or cannot afford the high cost of a hearing aid.
I worked with high quality telephone and video conferencing systems. They use a digital echo canceller to make a model of the acoustics (frequencies and their phases) and use it to cancel feedback sounds.
Hearing aids should also do it like that.
Hearing aids with front, back, left and right mics can use a comparator to determine the loudest sounds at voice vowel frequencies and their direction.
« Reply #28 on: December 31, 2016, 05:24:52 PM »
Yes, I admit as a shopper I am a "bottom feeder", and look for cheap stuff, as long as it works I am willing to put up with strange imported stuff. Hate to waste resources. I looked up lg.com, and didn't find anything in the way of hearing aids. Although they do lots of cell phones, washing machines, monitors and other stuff.
Actually I'm a licensed architect and not an electronics whiz, although I have built electronic stuff in the past, remember HeathKit? Have a special interest in what they used to call "Appropriate Technology", things that help people in village cultures in developing countries live a bit better, especially.
Its good to hear you folks (esp Hasan and Audio) sitting down and study this hearing thing, trying to figure out what people really need in the way of features and benefits, and what is possible. Its important.
« Last Edit: December 31, 2016, 05:32:43 PM by WonderWheeler »
  • Country: kr
« Reply #29 on: January 03, 2017, 07:08:08 PM »
Dear Sir Audioguru,
Hope you celebrate a very special "Happy New Year". :-+
Lets pray for you to have a nice staring of 2017. :)
Sorry for my late reply, I was busy on PCB design.
Dont you mean its a build-in IC? I saw a small size SpO2 (pulse-oxymeter) from German company, its main mcu was really hidden and I found no further information other then simple SPI data reading format.
I worked with high quality telephone and video conferencing systems. They use a digital echo canceller to make a model of the acoustics (frequencies and their phases) and use it to cancel feedback sounds.Hearing aids should also do it like that.
Didnt you get any idea of  "echo canceller" on circuits ? It might be in case of software resolution on signal. I dont know how unwanted signals could cancel through DSP, its obviously far away from any hardware filter. Patterns of speech, tone etc component could be meaningful if you play with them in algorithm. Most interesting thing is how the data looks like? How you captured them on program.
Well said, even the initial design could be bulky but we can see  how the loudest sound gain on particular frequencies changes on direction.
Regards
Hasan
Hasan
  • Country: kr
« Reply #30 on: January 03, 2017, 07:21:14 PM »
Happy new year 2017.
Thank you as you noticed our conversation.
LG is not interested on small size medical device I heard.
Could you kindly talk more about it,  "telemedicine " facilities is being popular in the region I have born.
Best Regards
Hasan
Hasan
Offline BrianHG
« Reply #31 on: January 03, 2017, 11:00:43 PM »
I am curious if anyone has though of using a beamforming microphone, there is one on my laptop for video conferencing in noisy environments like a coffee shop.  Combine such a mic with active acoustic cancellation headphones (ear bud sized) with audio input on each ear for the hearing impaired.  The headphones gets rid of all outside sounds completely while a forward aimed beamforming mic would really focus ones hearing on whoever they are looking at in front of them even in a noisy environment.  Obviously for the mic, you should also be able to EQ it, but you wouldn't have to worry as much about feedback.  I do realize this is a costly combination of tech.
__________
BrianHG.
Offline Audioguru
« Reply #32 on: January 04, 2017, 03:33:26 AM »
The conference system that I worked with used a digital echo-canceller IC that required setup by playing pink noise through the speakers into the room and the mic picked it up and compared it with the original signal and made a model of the acoustics (frequencies and their phases) of the room. Then when sounds from the speakers are picked up by the microphones the echo canceller circuit cancelled them from producing acoustical feedback. It even worked with long distance that has a delay: I talk and my voice goes to the distant end where its mic picks up the speaker sound and the echo canceller at the distant end prevented my voice from coming back to me as an echo.
Since my hearing aids use 4 microphones and since the one that has the strongest sound pickup is given the most gain, then the mics must be directional. Noise cancellation is also done in my hearing aids except not in the Music Mode.
Frequently when I am in a store or in a mall I hear a song that I like playing very faintly on the background music system. I push the button on my hearing aid so that they go into the very sensitive mode then I hear the music playing loud and clear. The background noise does not increase so it must be cancelled a little and I think the very high frequencies are reduced a little.
Offline m98
« Reply #33 on: January 04, 2017, 03:48:23 AM »
The following users thanked this post: BrianHG, Md Mubdiul Hasan
Offline BrianHG
__________
BrianHG.
Offline Audioguru
« Reply #35 on: January 04, 2017, 05:39:07 AM »
The WOW opamp is fantastic when it has a 1V supply. It could be used in a simple DIY hearing aid.
Offline BrianHG
« Reply #36 on: January 04, 2017, 03:53:04 PM »
The WOW opamp is rated to work at 0.9v.  Maybe a fraction lower.
With a little tuning of the circuit below for adjusting 3 frequency bands something like 3khz 6khz & 10khz, you can make a cheap but fairly functional device.
__________
BrianHG.
Offline Inflex
    • Charters Towers Phone & Computer Repairs
« Reply #37 on: January 04, 2017, 04:05:06 PM »
Watching with interest. Ever since I sadly washed my hearing-aids at the age of 22 (a loooooong time ago now) I've just gotten on with life without them because of the cost, thank goodness for the internet and everyone being able to communicate using text   :-+
Magicsmoke abuser | What I repair daily on YouTube | OpenBoardViewer | Paul Daniels
  • Country: kr
« Reply #38 on: January 04, 2017, 05:47:10 PM »
Thank you sir BrianHG,
Welcome to my post.
Did you read any article on this? Kindly explain more.
Any particular design will be appreciable.
Hasan
  • Country: kr
« Reply #39 on: January 04, 2017, 05:52:08 PM »
Yes, Mr. salbayeng also suggest this design in this post.
« Last Edit: January 04, 2017, 06:08:44 PM by Md Mubdiul Hasan »
Hasan
  • Country: kr
« Reply #40 on: January 04, 2017, 05:54:36 PM »
Sir  m98.
Thank you for useful datasheet.
Need to think for application circuits.
« Last Edit: January 04, 2017, 05:56:19 PM by Md Mubdiul Hasan »
Hasan
Offline Inflex
« Reply #41 on: January 04, 2017, 05:57:08 PM »
When I was a student at high-school, I tried the headphone / directed-microphone system, using a portable FM pocket radio and a "Talking Electronics" FM Bug with a shrouded mic, it was an excellent combination for me, so yes, being able to focus on sounds is a great idea when you're talking to people.
A system I want to try build here now is something which picks up sounds from all around the house and mixes them with the audio in the room I'm in; sort of giving me far greater situational-awareness.  I like to be able to hear if my cats are calling out to me / in trouble, or likewise my wife.
  • Country: kr
« Reply #42 on: January 04, 2017, 05:58:27 PM »
I see, in old days which circuits you were interest in?
Hasan
  • Country: kr
« Reply #43 on: January 04, 2017, 06:04:09 PM »
What noise level you are thinking ? What senors you are trying to use ?
Cant you combined with possible earth quack signals that is important now in a risky area.
Hasan
Offline Audioguru
« Reply #44 on: January 05, 2017, 02:37:45 AM »
The maximum amount of high frequency boost in the simple tone controls circuit is 10dB which is good for a man no older than about 30 years old according to the normal hearing loss graph I posted. Today I am 71 years old with a normal more than 40dB of loss at 10kHz and my audio system's treble tone control does almost nothing without my hearing aids and their more than 40dB of boost.
60 years ago hearing aids produced telephone quality (300Hz to 2kHz)*. Music goes to 20kHz and speech goes to at least 14kHz and modern hearing aids play them well.
The earmolds for my hearing aids have vents so that air pressure changes are allowed then they do not cause a "plugged feeling" and the vents also allow normal level low frequencies to be heard directly. but the vents cause feedback that must be eliminated.
When you make a whole house microphone system then you will have feedback unless you wear sealed headphones. Maybe the microphone system can light a bulb or ring a bell instead (and something to turn them off).
* I measured a loss of -12dB at 3kHz on a telephone line at work. I complained to Bell and they said it is fine and is better than their maximum allowed loss of -15dB. The response began dropping at 1kHz. Vowels only.
Offline digital_dreamer
« Reply #45 on: January 05, 2017, 02:32:16 PM »
My hearing aids are Starkey Destiny 400 BTE (Behind The Ear) and implement a anti-feedback algorithm where the output is frequency shifted (up or down, don't remember which), so that each time it re-enters, it's continually shifted until nulled. It's quite effective, as one of the more embarrassing things that can happen is having your aids hanging off your ear or in your pocket while still turned on and people looking at you like WTH is going on with you?  ::) Not anymore with these. These are the first digital ones I stuck with, as I hadn't had good experiences with digital. Really prefer the old analog.
I'm 52 and have worn aids all my life, as I was born with profound hearing loss from birth, like my twin brother. My frequency loss starts at 500Hz, yes, really. And, is off the chart at 2KHz (below -110db), so no amount of amplification is going to help there.
We always wear BTE, as they are the only types that usually have the power needed with the large enough battery to last.
Funny story: Hearing loss got me started in electronics and sound. I started tinkering with amplifiers as a kid and entered a regional Science Fair at age 13 and won first place in Physics with a telephone amplifier I hacked together from a radio and a magnetic pickup coil. I still had a lot to learn, as I used a linear pot for the volume control and demonstrated that there was still plenty of volume when turned all the way down. LOL. :-DD
I'm a digital guy through and through, however, building digital circuits and programming MCUs and such.
Anyhow, I'm enjoying this thread and applaud any efforts in this field. As much as I enjoy technology and having the latest of the greatest, my experience with aids has exposed many problems in this field. The aids offer so many features and options that my main aid seller, as well as several other "professionals" that offered to fine tune these aids and fix my issues, were baffled for hours trying to figure out what to do and what to change on the software connected to the aids. This took many visits and I was left giving up on having some issues ever resolved.
One of the issues was the hearing aid confusing music as noise and always tuning it out. This was a problem I had many years prior when I was testing out a digital aid. I worked in a printing plant and needed to hear the equipment running, including pressurized air or vacuum, and drive motors. Having the aids constantly trying to tune out the sounds was extremely annoying, so I returned them. I needed to hear the noise! This was finally fixed, however, by finding a way to turn it OFF. Probably a disappointment to the team of DSP programmers who spend weeks/months making this "work."
The other issue was just simply having the telephone pickup work. This was supposed to work automatically or you could switch it manually. But, no. Unlike any hearing aid in the past, I cannot use these on any hearing-aid compatible phone. What's the point offering all these bells and whistles if no one knows how to make it all work? Inexcusable for a $3000/aid system.
Now, I like the idea of BT enabled aids and other features, but when it really comes down to it, all we really need is a good, low-power, sensitive mic, amplifier, and transducer, coupled with a 2 or 3-band filter. Everything else is gravy.
MAJ
Offline Audioguru
« Reply #46 on: January 05, 2017, 02:56:21 PM »
I tried frequency shifting to eliminate feedback in a PA system but it added strange sounds.
The echo canceller in conference systems also made weird sounds when the acoustics in the room changed due to many people coming or going and it got confused since its model of the acoustics is different.
  • Country: kr
« Reply #47 on: January 06, 2017, 05:17:01 PM »
Hello,
Thank you to join here :)
Let me know your digital design more.
For real application, what did you feel for size of battery.?
Dont you think, its more about Physics rather then engineering work!
What MCUs you have programmed, did those related with PA,Hearing aid or telephone system?
Well, keep stay with us. For the case of software and firmware ,things might not easy if you apply a centered MCU with circuits. Its a challenge indeed.
From this post response, people directed me in right way! Even we want to think in different angle.
Right you are ! annoying work kills your brain.
Explain your experience more.
Hasan
  • Country: kr
« Reply #48 on: January 06, 2017, 05:20:24 PM »
When you were talking about "feedback" microphone system, I feel need to work on that on my design.
Hasan
  • Country: kr
« Reply #49 on: January 06, 2017, 05:23:01 PM »
For the case of acoustics and echo canceller, cant we use a simulation software ?
Can you remember from your stock ?
Hasan
Offline Audioguru
« Reply #50 on: January 07, 2017, 12:30:10 AM »
At first, the echo canceller makes a model of the acoustics of the room when pink noise is played through the speakers and is picked up by the microphones and its frequency response and phases are analyzed and saved. The echo canceller is "adaptive" so it tries to use incoming speech as its signal and makes changes to the model of the room acoustics to make the model accurate if it detects changes to the model.
Cirrus Logic and other manufacturers make echo canceller ICs. Polycom speakerphones use an echo canceller so that they are "full duplex" (you can talk and listen at the same time without having feedback or switching).
« Reply #51 on: January 07, 2017, 11:01:28 AM »
Best Regards
Hasan
Hasan:
"Appropriate Technology" in the US, was a reaction against the 1970s culture that created the "Vietnam War", environmental pollution, and overconsumption and waste of natural resources. https://en.wikipedia.org/wiki/Appropriate_technology  Smart, long haired college students, that were shall we say smokers rather than drinkers, thought that maybe a new type of technology could fix culture. Something that involved village scaled technologies, using methane digestors to produce gas, solar water heating, rammed earth walls, solar electricity, vegitarianism, windmills, democracy, cooperative businesses and other low tech solutions.
The state of California even had an office called OAT, where some friends and I got a small grant to do a video on solar in the 70s.
It later looked like A.T. was just wishful thinking, and right wing polititions took control.... sorta like today, lol
Regardless... a small durable cheap open source hearing aid could do a lot for poor people around the world. Partial hearing loss due to age or an infection.
« Last Edit: January 07, 2017, 11:18:55 AM by WonderWheeler »
  • Country: kr
« Reply #52 on: January 09, 2017, 02:40:59 PM »
Thank you to describe things well.
Let me write beside your comments.
"environmental pollution, and overconsumption and waste of natural resources.
Beside "robots" what electronics idea you can imagine for such solution ?
Nice, still those solution is MUST in developing countries.
A short lasting cheap circuit has good business in my country, I am looking for a good design at least to start. Need to develop a patent  that cant be copied by others.
Hasan
Offline Audioguru
« Reply #53 on: January 10, 2017, 04:04:45 AM »
A patent is given to somebody who invents something that has not been done before. Hearing aid circuits are not new and cannot be patented.
You want to design a hearing aid that is CHEAP with poor performance. There are many of them in China, look at Banggood.
  • Country: kr
« Reply #54 on: January 10, 2017, 06:45:45 PM »
Thank you sir  :clap:
You might talking a very tinny one, lets see inside.
Hasan
