Author Topic: A susbstitute for the 7812 Regulator  (Read 1132 times)
Offline VanitarNordicTopic starter
« on: October 21, 2018, 11:04:15 pm »
I am looking for a substitute of the general purpose 7812 which should introduce lower dropout and more stability, load regulations and so on ...  :popcorn:
No switching, only linear and easy to find
Online oPossum
Re: A susbstitute for the 7812 Regulator
« Reply #1 on: October 21, 2018, 11:10:19 pm »
LM1117-ADJ
Proper capacitors must be used for stability.
http://www.ti.com/lit/ds/symlink/lm1117.pdf
Also made by many other manufacturers.
The following users thanked this post: VanitarNordic
« Reply #2 on: October 21, 2018, 11:29:45 pm »
LM1117-ADJ
Thanks, but I'm looking for a fixed output voltage, it is preferable. Besides, for SMD ones, the heatsink is a challenge. The current draw could reach 500mA.
Offline DaJMasta
    • medpants.com
« Reply #3 on: October 22, 2018, 12:00:44 am »
I mean, a variable regulator is a fixed regulator with external feedback resistors, but also the 1117 comes in flavors with integrated feedback resistors to have only the fixed output voltage.  Typically denoted as 1117-12 or 1117-3.3 or somesuch.  SMD packages also offer heatsinking through their tab through the board, and with lesser thermal transfer you can still stick a heatsink on the package itself.  There are options if you are not constrained to a TO-220 footprint.
Otherwise, there are both some other variants that could be good choices, and there are many circuit variations of the classic 7812 that give you more CMRR, lower drop out voltage, or are binned for tighter regulation.  There was a time when they were somewhat similar, but I think you'll find that a survey of several 7812 marked modern parts will turn up quite a number of differing implementations with different characteristics.
Online SiliconWizard
« Reply #4 on: October 22, 2018, 12:07:22 am »
The following users thanked this post: oPossum, VanitarNordic
