True, but they probably wanted a power source for an external antenna amplifier, and many of those run nicely on 28VDC with good gain, so they optimised for that so the major use would work best. Powering an external antenna up the power cable is common, and there are only 2 standards, the old one of 60VAC and the more common one of 28VDC.
