I am just getting started with this, second sit down with the new scope. Did a little bit more coding, and captured my first waveform - the scope signal source on the bottom right. Super easy to do. If there is anyone interested in code examples, I'll continue on providing them, otherwise I will wait until I have a full operational network remote control panel up and running. Maybe I post my project on my website. What is posted here should be enough for anyone who is also a programmer to remote the scope.
First thing I did is a :MEAS command to get the waveform frequency. That worked. Next I did a data read, as described from page 2-208 of the Programming guide(which can be found on the Rigol website).
The data is in ascii(Unsigned 8 bit). Simple LabVIEW string to byte array did the trick. Next - properly scale the axis on the graph..
