Author Topic: Altium pcb service  (Read 4221 times)
Offline Ultra67Topic starter
Altium pcb service
« on: July 27, 2017, 09:54:49 pm »
Good evening,
I need a PCB to be made in Altium in a short delay. Do you guys know any service that can make a PCB design, if one provides the footprints of all components and the schematics? I'm struggling with this PCB, I just discovered Altium...
Thanks a lot.
Offline bug13
Re: Altium pcb service
« Reply #1 on: July 27, 2017, 11:25:12 pm »
I may be able to help, pm me. I may be able to do it over the weekend. It's winter here, can't go out anyway.
Zhuhua Wu
A guy who creates stories to tell machines to do stuff.
Offline Aztlanpz
« Reply #2 on: July 27, 2017, 11:53:31 pm »
I can also do it and i can start today
Offline Alex Eisenhut
  • Place text here.
« Reply #3 on: July 28, 2017, 12:42:02 am »
How can anyone say if they're ready or not to "do" this PCB? How many components? Largest footprint? Densest pitch? Frequency range? Number of nets? Mechanical? Etc...
What if it turns out there's 6000 parts, 40Gbps optical transceivers and 2000 pin .5mm BGAs on both sides of the board, and that it has 15 power nets running several amps each, switching supplies everywhere, SDRAM buses, and it requires blind and buried vias on a 30 layer board?
You could spend a week just figuring out the correct way to break out one BGA!
A "short delay" for that could be 3 months.  8)
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: July 28, 2017, 12:56:50 am »
Also, if one provides the footprints but they're all wrong..... what then? :-//
DFM is another great service.  Though I probably don't have time right now, unfortunately.
Seven Transistor Labs, LLC
« Reply #5 on: August 01, 2017, 01:35:26 pm »
Thank you for all your responses ! I'm still looking for someone as no one is responding  ;D The PCB is not really complicated, the only constraint is that there's 20A at some nets of the circuit !
Offline Brumby
« Reply #6 on: August 02, 2017, 01:52:52 am »
... the only constraint is that there's 20A at some nets of the circuit !
That could be fun.
Offline aditya_electron
  • Country: in
« Reply #7 on: August 27, 2017, 11:39:20 am »
Kindly send the details. We provide Electronics Design services.
