Hmm.
Current entering the base will pull the top of the crystal down. Then eventually the voltage at the top of the 10K resistor drops, prohibiting the transistor from conducting. After the inductor collapses the top of the 10K resistor charges up again, also pulling the top of the crystal and base up. Repeat.
