Does anyone know of any examples of using the Analog Discovery SDK for creating custom instrument functions?
What I would like to do is be able to set the amplitude over frequency ranges in the network analyzer. For example, I might want an amplitude of 800mV over 10Hz to 400Hz then 50mV over 401Hz to 100kHz then back to 800mV.
The application is for Loop injection for DC/DC converters.
https://www.maximintegrated.com/en/app-notes/index.mvp/id/3245At low frequency and beyond the crossover the signals (Vo/Vi) can vary by 40dB or better. Trying to pick off a 1mV or so signal in a noisy say switching converter would be difficult to say the least. Variable amplitude over frequency is how dedicated FRA’s deal with this problem.
An example picture of the problem is below.
I am using high-speed op-amps (OPA2354 or OPA365) AC coupled through BNC connectors to the test circuit. I’m using these as 5x gain block.
I’m also open to alternate suggestions, other than buy a $10k FRA of course. I’m not being overly ambitious a frequency range from 100Hz to say 500kHz would be fine. I already have a transformer that gives me a flat response over 400Hz to 1 MHz.
