Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
ANALOG TO DIGITAL CONVERTER FOR INDUSTRIAL APPLICATIONS
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: ANALOG TO DIGITAL CONVERTER FOR INDUSTRIAL APPLICATIONS (Read 1471 times)
cRash1001
Contributor
Country:
on:
January 08, 2017, 06:44:00 am »
I have been using R1SE-0505/H2-R for isolated power supply for ADC MAX1300. I was told that using the R1SE for power supply will be same as just using a LDO to supply the ADC. So, what would be better to supply power to the ADC a low noise LDO or isolated power through R1SE-0505/H2-R? Inside R1SE-0505/H2-R is a transformer with some components for oscillation.
Logged
kiran_shrestha
Regular Contributor
Country:
Kiran
Re: ANALOG TO DIGITAL CONVERTER FOR INDUSTRIAL APPLICATIONS
Reply #1 on:
January 08, 2017, 02:36:56 pm »
No.. you should use small LDO after R1SE because R1SE output is not so good for ADC... I have tried it... by the way are u making isolated current sensing...hahah.. just wondering...
Logged
Thats all
cRash1001
cRash1001
Contributor
Country:
Reply #2 on:
January 10, 2017, 02:47:30 am »
Kiran bro, its me ditish. Its actullly for industrial application, probably for to work in conjuction with PLC or something. So, its better if just use a low noise LDO instead of R1se?
Logged
kiran_shrestha
Regular Contributor
Country:
Kiran
Reply #3 on:
January 10, 2017, 06:17:18 am »
I though so ..
as I have bought R1se long before.... R1SE is isolator and u can use LDO after it and run adc in low voltage 2.8 or 3.3 as R1SE has output is 5V for 5v input.
Logged
Thats all
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
