Hi, szabolcsx. Yeah, as you can probably see from this thread, electronics has been moving slowly for me lately.
The documentation's a ways off as is just about everything else.
Okay, the current sense amplifier. First, the simple part: why is it connected to +2V? Because it needs "headroom" above the 0V positive output line. In order for it to work, Q23A has to pull its collector at least 1.3V (two transistor thresholds) down, so that both Q24 and Q19 turn on. If it were connected to 0V instead, the collector would drop below the base, forward-biasing the base-collector junction and preventing the transistor from turning on any more.
Now, for the actual operation: R47 is in the path of the output current, and acts as a sense resistor. The left side of that resistor sits at 0V, and the right side drops down by Ohm's law as the current through it increases.
A voltage divider between 0V (the left side of R47) and -12V allows you to set a threshold voltage, which is
connected to Q23A's base. The actual current sense voltage goes to Q23B's base. The emitters, which are joined together, will go to whichever voltage is lower, and then R44 acts as a current source to pass about 1mA through the two transistors.
Normally, the current sense voltage (on Q23B) will be higher. Q23B is then the only transistor whose base is above the base-emitter threshold, so only Q23B is active. When the current sense voltage falls to the threshold voltage, though, both transistors have equal base voltages, and they
both turn on. If it falls even more, only Q23A will remain on.
If the balance shifts enough towards Q23A that there is about 650µA flowing through it, each of R42 and R43 will produce 0.65V, about a transistor threshold, turning on both Q24 and Q19. Q19 sources current to LED DS2, activating the 'limit' LED. Q24 pushes the FB+ line higher, which makes the main error amplifier think the output is too large. The output is then decreased until Q23A and Q23B are balanced.
Let me know if I haven't explained something well, as I don't know what point you're at in your learning.
Would you care to share your LTspice file with me?
