Oh wow, thanks to both Galaxyrise and B@W, looks like you really spend some time reading through it.
Galaxyrise:
- Yup, no green lines would be better. I agree, they are misleading.
- I'll add an explanation rather than changing the voltage spans. They're like that for a reason: I'm showing the differential voltages that
matter: Vbias->VCC (which biases current sources), VEE->V+ (which supplies the regulator), the total V- ->V+ span (which shows the possible output voltage span, as I will address in a section I haven't yet written), and the V+->Vbias headroom (which proves that the current sources won't ever saturate). All others are incidental.
- I did indeed pick a net as ground in SPICE, but it was inconvenient. Many voltages made more sense relative to a different rail. I used V+ as ground because it ruined fewer nice numbers than any other. That's pretty common in discrete-transistor circuits: "ground" is whatever an individual transistor sees at its emitter.
- C6 charging math: 3.5V is Vmax because until the Zener diode begins to conduct, it's not really there. The capacitor charges as if 2.4V doesn't exist and it's just charging towards the rail. The Zener will suddenly clamp it at 2.4V. I'll add a note to this effect.
- No comment on the tempco yet - from reading both you and B@W, it looks like I've got to spend a bit of time rechecking that. There probably is something wrong with it. I'll dig into it a bit later - just got up for morning coffee and have to do other things first.....
- You're right, I should explain R1. Added.
nits:
- Front-panel Voltage potentiometer: Capitalization is correct, and I will add quotation marks as well. It's not a "voltage potentiometer", all potentiometers are (
potentiometer!!!!). It's a "Voltage" potentiometer, as in, that is its label.
- Yep, that sentence is awful.
Bored@Work:
- You are absolutely correct about DC voltage needing a direction label. I was careless to just assume the "positive up" convention. I will change the arrows to all point to negative, but I will also add + and - labels, as arrow direction convention can confuse beginners.
- I wasn't sure whether I wanted to label quantities like that. It does make it easier to refer to them, and it is of course standard practice in academic papers and such, but in my experience the uninitiated can find that it makes the text seem denser and harder to follow. I'm still not sure. I'll have to consider this one.
- I really like that NIST checklist. Definitely going to add that to my collection. And use it here, of course
- Ew... magic equations and math without units. Did I really do that?
I'm so sorry for anyone who had to see that. Fixed!
- And as mentioned above, I think you are right about the error calculation. I'll go over that again a bit later today.
