Author Topic: anyone knows a distance sensor (steps 0,2mm) with digital protocol interface ?  (Read 344 times)
Offline Kjelt
Hi can someone recommend a distance sensor with the following properties:
- contactless measurement (so ultra sound/light or other means)
- distance 0-30cm
- accuracy 0,2 mm or better
- output: digital protocol , preferred rs485 or something resilient like that.
- price: around $50 not that important
What I found were some ultrasound sensors but they all have an analog output, or programmable binary output for a certain distance.
I can not find one that returns the measured distance over a protocol. I could interface it with a uC myself but rather have it integrated in the sensor.
« Last Edit: August 14, 2018, 06:59:06 pm by Kjelt »
Offline CM800
- distance 0-30cm
Are you able to attach something to it? e.g. a suitable reflective surface, optics etc.?
Have a look at these:
https://www.baumer.com/gb/en/product-overview/distance-measurement/optical-distance-sensors-/c/289
« Last Edit: August 14, 2018, 07:13:28 pm by CM800 »
Offline Kjelt
Good question, answer is no  :(
The object is not reflective.
I need to move the object into a certain distance so I have to measure the distance during the move till it is in the right position.
Offline StillTrying
  • 100% Brand New and High Quality, in theory.
- distance 0-30cm
I'd be surprised if you find anything that can do 0.07%+ accuracy over that distance!
Online AndyC_772
  • Will design for cookies
This can be done with a magnetic sensor, though it won't be $50. PM me if you'd like some details.
(Dis)claimer: I designed it.
The following users thanked this post: Kjelt
Online odessa
Time of flight sensors are pretty accurate and use I2C
Look at the VL53L1, there's an arduino library available for it too
When  I die I want to die peacefully in my sleep like my Grandad ... Not all shouting and screaming like the passengers on his bus.
Offline Kjelt
Thanks but two issues: starts at 40mm and error is +/-20mm but interesting little thingy for other purposes  :)
