Author Topic: Anything wrong with this linear PSU design? (now selecting parts)  (Read 33905 times)
Offline PowermaxTopic starter
Re: Anything wrong with this linear PSU design? (now selecting parts)
« Reply #125 on: January 16, 2017, 06:01:48 am »
On an unrelated note, I bought those transistors to drive a flyback transformer as replacements for some more expensive MOSFETs. I wanted to see how BJTs would compare to MOSFETs in this application. Those were dirt cheap so I thought I'd give them a try. I was disappointed in the results.  :--
Is there much I can do to reduce the Vce voltage and really drive them hard into saturation? I tried making a darlington but quickly found out that unless I use 2 of those transistors, then the small one will die (due to high voltage transients in flyback operation). Using 2 of them defeats the cost benefit of my favorite FTP33N25 MOSFET (a modern more-or-less equivalent to the IRFP250N with simalar ratings)
Interestingly, the TIP120 gave me amazing results!!!! (nice fat juicy white arcs, almost as good as the MOSFET), For about 2 seconds, till' it died.  :(
So I know of the darlington configuration, and the complementary pair, and after asking this question on Instructables, and I did receive a very interesting configuration shown below, but other than that, what other classic or common BJT circuits exist for high power switching?
Offline David Hess
  • DavidH
« Reply #126 on: January 16, 2017, 01:14:00 pm »
Use different transistor types in ways that take maximum advantage of their strengths.  Use the PHE13009 in common base configuration and drive the emitter with a cheap high current low voltage n-channel power MOSFET:
http://electronicdesign.com/power/cascode-configured-gan-switch-enables-faster-switching-frequencies-and-lower-losses
Online VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #127 on: January 20, 2017, 12:17:30 pm »
FTP33N25 MOSFET
this thing has an SMD version, how can it be used in such designs? and also how to dissipate heat?
