So I have a car that doesn't have bluetooth but does have an auxilliary input. So just use a headphone to RCA cable and all will be fine.... well fine until you want to charge the phone from the car charger. I don't know if it's particularly a problem with my model of car (Lancer CJ), but this causes a whine that goes higher and louder with the engine revs.
I recognised this as a ground loop issue but of course didn't want to spend money fixing it. So I was looking at my collection of random boards, and found a PSU board from an old Sony BVM that had 2 common mode chokes, both identical. Essentially they are just transformers and there were 2 identical ones.
So I hooked one to my signal generator and scope and the response is suprisingly flat from the low 10's of Hz up to at least 100kHz.
I wired them up to some connectors and tried it out and it works no problem!
