One problem with larger SMD packages is the mismatch in thermal expansion between the component and the PCB laminate itself. Tests have shown that a 2512 sized resistor and its soldering will not be able to survive a full lifetime of the car, even when placed in the driver's compartment and not under the hood. It does not have anything to do with leaded or lead free solder, both alloys failed, and with several types of plating on the PCB (ENIG, HASL...). The solution is to split up the resistance into several smaller packages, typically 0805 or 1206.
By only relying on increased series resistance, you will also make the signal more sensitive to component tolerances, leakage currents etc. It might be ok for a low frequency, low resolution signal, but the accuracy of a sensor will suffer and can go out out spec.
