"Balancing doesn't waste any time at all. It doesn't matter if you charge each cell separately at 1A or the entire pack at 1A, the time it takes the whole pack to finish charging will be determined by the time it takes the last cell to finish charging. For all of this effort, you will not save any time."
that make no sense at all....
did i understand the video wrong??
https://youtu.be/wIbHLacozFo?t=368where he explains the balance charger will charge in parallel and once a cell reaches full, it STOPS and discharges them.
(there for not charging and wasting time discharging)
and when charging a series pack in parallel is each sell getting - 1000mah / 3 = 333mah or each cell is getting 1000mah l (max) ??
again the point is to find a way to charge a mix 18650 that may not be the same condition, quickly with out wasting time to discharge.
even a cleaver way to put a switch between each cell to isolate them while charging is a more simple option.
the battery packs will be running boost converters anyway and using recycled battery's
forget the diagram #13 is was just a example i found, i am looking for a solution's not an excuse. thanks
