Our contractor thinks that the balancing of series stacked supercapacitors during charging is needed because of differences in leakage current. However, we keep telling him that charging of series stacks needs balancing due to the tolerance differences in capacitance from cell to cell. Do you agree? (When the charger goes onto "float charge", thenn the leakage current effects take over)
Also, the problems inherent to charging batteries in parallel with a single charging current source do not exist for paralleled supercapacitors. This is because if one paralleled supercapacitor hogs all the charging current then it will not overheat like a battery could. Do you agree?
The great advantage of supercapacitors in series stacks, that is never mentioned anywhere, is that if series stacked supercapacitors are discharged, then even if they have massively different capacitance values, no single capacitor gets a damaging reverse bias voltage whilst the others have a positive voltage......this makes supercapacitors better than batteries...because a series stack of cells can see one cell go negative voltage whilst the others are positive voltage...destroying that cell.
Why is this great superb advantage of supercapacitors never mentioned..anywhere?
