I have accumulated (no pun intended) dozens of AA NiMH cells, and i wanted to know what state they were in, what they were basically capable of, and hopefully sort some good ones into a couple 12V packs by matching capacity.
For that i built a simple discharge logging rig - an atmega88 logs the battery voltages with it's ADC, and sends the data back to a PC.
Each battery is connected in series with a 3 Ohm resistor and a N-FET to cut it off once it reaches 0.8V.
Simple, right?
Well, several days later i don't think so any more.
The discharges give wildly different results from run to run.
Same cells can show up to half or twice the capacity from the previous runs.
Same cell can show a lot on run 1, a little on run 2, and a lot again on run 3, while the other in the same batch shows the opposite.
There is some consistency - like one weak cell always shows up somewhat behind the others (but vary by itself too).
Naturally, i suspected the rig.
It's on a breadboard, so there are many options for loose connections.
However, all the numbers seem to check out - the voltage drops are consistent, total of 0.05V difference between the resistor and the battery terminals.
The voltage drop across the resistors is consistent, meaning a consistent load.
There are no loose or unstable connections - an mV or 5 if i roll the battery inside a socket is the most i could produce, certainly nothing sufficient to account for tens of % of difference.
Finally, i checked the rig on a fresh set of alkalines, and got nearly-identical results on all cells.
The rig appears solid.
Are there any apparent flaws in it?I suspected the procedure.
The batteries are always put into the same slot (and charger) on both charger and discharger each time.
The batteries are charged, then set aside for 5 to 10 hours to cool down and stabilise, then discharged, then cooled off for 30 minutes to several hours, and put back into a charger.
I tried to keep the times consistent for a couple of cycles i can pull off within one day (one discharge takes 6 hours), with no effect.
Are any of these times important?The last suspect is the charger.
The chargers, two identical ones, are your basic chineese microprocessor-controlled 8 cells chargers with dV detection.
They neither look nor were especially cheap.
I figured out they can fully charge a cell, but by now the chargers are the only remaining suspect.
Is it at all plausible that this kind of a charger can partially charge a cell just like that?All in all, i'm no longer sure what else can be wrong.
Anyone have any other ideas?The only remaining assumption is that a NiMH cell should always have the same capacity under the same load, at least within a few cycles.
