Author Topic: best battery for low noise preamplifier?  (Read 2669 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
« on: April 18, 2014, 06:28:14 pm »
So I need a power source for my pre amplifier.
I need ~4-5 volts per rail.. (bipolar)
two options come to mind:
4x lithium battery for +-6v. I like this solution because I could seal the whole thing up well and just leave a external jack and switch to plug it into a lab power supply for charging (I don't expect this thing to be used much).
rechargable c/d cells - I don't know how many I need, 6 I assume (1.5x6 for 4.5--4.5v).
The problem is that I don't have a charger for these cells, so I would need to buy one, since you can't recharge certain battery types with a lab power supply (I would need to keep track of temperature and its kind of a pain).
I have eneloop AA rechargeable batteries. They are nice but they are only 1.3V, so I would probably need four of them per rail, and that is not much current (I expect this to take ~50-100mA).
Eneloops would cost 20$ and require dis assembly for recharging.
I am not sure what type of lithium battery I would use, I 3000+mAh would be nice.
I wanted to run the op-amp just from the batteries without a regulator to keep the circuit simple.
Offline Andreas
Re: best battery for low noise preamplifier?
« Reply #1 on: April 18, 2014, 06:35:25 pm »
I have tried to test eneloop AA batteries (packs of 8 AA cells) for noise.
Noise is lower than my noise amplifier (around 0.12 uVpp at Input)
so I could not measure the noise of the AA cells.
With best regards
Andreas
Offline Richard Crowley
  • KJ7YLK
« Reply #2 on: April 18, 2014, 06:38:06 pm »
So I need a power source for my pre amplifier....
I don't expect this thing to be used much)....
... to keep the circuit simple.
Why not use ordinary primary cells?  Why even fool around with rechargable for something "not used much"?
« Reply #3 on: April 18, 2014, 06:51:26 pm »
cant help myself addiction  :-[
Offline rdl
« Reply #4 on: April 18, 2014, 07:09:35 pm »
So how were you planning to charge the lithium batteries from your lab supply?
« Reply #5 on: April 18, 2014, 07:10:38 pm »
constant current then constant voltage based on batteries charge capacity.
Its how I charge my flashlight batteries.
i have a whole bunch of switches here on hand too.
« Last Edit: April 18, 2014, 07:13:13 pm by SArepairman »
