Update,
Building the turret board and the placement the components in the chassis has required a bit of rethinking and adjustment. I changed from the original power transformer to another one which will require an adapter plate as it has a smaller cut out dimension. More adventures in G Code for the CNC mill...lol I have yet to master the tool offset issues yet. If you want to mess things up, use a computer. If you really want to mess things up, have that computer direct the actions of a four axis milling machine...lol
I still have not made up my mind about the placement of the filter capacitors. Fender typically placed them on top of the chassis and contained them inside a cover plate on a small board. I may try to place them (there are five 16mf 475V caps) inside the chassis under the potentiometers...not sure yet.
Here is a photo of the almost finished turret board. The transformers will arrive tomorrow and I want to place everything before I drill the mounting holes in the turret board. There has been more time and work involved in defining a step by step build process than I assumed there would be. The electronic issues are proving to be easer to deal with than the logistics of the construction.
If I had this to do over again, I would not try to use a head cabinet that I had laying around. It would have been much better to build a new cabinet to fit a slightly larger chassis. Space limitations in the old cabinet have caused me to make compromises which are problematic.
At the end of the day everything comes down to the issue of money...lol
Cheers,
Billy
