The pro systems I have worked with always develop trouble in the spiders (the support system for the moving part). Seems like that would be where I would look for trouble first. The requirements are contradictory (support lots of load, have zero friction, zero spring constant and infinite fatigue life.) The spiders that come with the speakers suffice for a perfectly balanced and symmetrical load, but are likely to give "interesting" results with your sensors mounted since they are unlikely to be perfectly balanced with symmetrical moments. The voice coil clearances in speakers are designed with those same symmetries in mind. It allows higher magnetic efficiency than in a system that has to allow for more sway and tilt.
I know you have had some success before, but I suspect you also had limited life and some strange times matching your sensor response to the drive.
