Google is your friend:
http://cdn.teledynelecroy.com/files/whitepapers/interleaving_process_in_dbi_scopes.pdf
http://download.tek.com/document/55W-29371-2%20ATI%20Whitepaper.pdf
http://www.analog.com/en/analog-dialogue/articles/whats-up-with-digital-downconverters-part-1.html
you are refering mostly to how modern DSO architecture sampling works at higher speed, either by interleaved/up sampling or downconverting. are you saying i'm correct with the idea that RTSA work in similar way as modern DSO?
They either operate in a sweep mode where the centre frequency is moved in steps to cover the entine span, or in staring mode when the span is less than the instantaneous bandwidth. In staring mode you have the ability to have 100% chance of seeing any short transient signals and can normally set a trigger to capture these.
i'm interested in how this so called "staring" mode (ie 100% probability capture chance) works. thats why i ask, since sweep mode may lose some intermittent signal (usually in frequency hopping radio transmitter). my best guess so far after the RTSA is triggered, it will sample as fast as it designed to be, in sequential manner similar to DSO...
I believe the ‘Real Time’ part means that the FFTs are done fast enough to keep up with the ADX samples (instead of capturing a buffer and FFTinf it now and again).
I also understand that to get 100% probability of detection you need to overlap several FFTs in time (think like overlapping brocks).
from my understanding reading signalhound literature, 100% probability of detection is due to the trigger mechanism tuned for a particular spectrum, once the spectrum is detected, the RTSA will capture the rest of the signal for display, but how exactly done, is not described. i have a strong belief that multiple overlapping FFTs method is used to enable the small chunk of FFTs are calculated in parallel in quick time so "real time" experience will be realized virtually, the result of these multiple FFTs will be combined in some (proprietary or paid IEEE?) way to achieve greater FFT resolution, it has been mentioned by some members here time ago.
Finally, I hear that if you manage to make a fierce enough instrument you may run into military export restrictions.
I’m conclusion, FEAR THE MULTIPLIERS!
this thread, or this forum for this matter is not about complying or fear to this restriction. yes its been discussed in signalhound thread and link to their reply how they crippled their SW to comply with this restriction. but i guess this rule is only worth concerning in high greater than 10's of GHz of BW, which i believe still beyond the reach of hobby purpose in components cost alone, let alone the expertise to design the PCB at those RF BW.
i'm thinking this thread more as preliminary education or insight lets say if we want to design a smaller scale RTSA at 10-100's MHz of BW or 1GHz BW tops. i saw several links to PIC RTSA at audio BW, but its too simplistic imo and impose less challenge. we can even make our DSO as RTSA by downloading data to PC and do FFT processing, but the experience will be far from "real time" and no spectrum trigger, and DSO will be alot less sensitive to RF due to their input attenuator (resistor divider) design. i need something more realistic and closer to practical application like implementation of SA attenuators, spectrum trigger, and then interleaved sampling (to lower buying cost of ADCs), fpga to save to memory maybe?, and then FFT processed by mcu or some dsp (multicore for parallel processing preferably).
