Hi folks!
After Dave's video about Bulova Accutrone 214 Spaceview I thought: "well... why not?" and after a month of search and waiting I bought 1967 model from eBay. The watch is in nearly perfect cosmetic condition. They were stated as "serviced" and they seem so. When left on the bench they run dead spot on, not a single second off by 24 hours. But when on my wrist... well... 25 second off forward each hour.
As mentioned before, this watch is designed for 1.35V mercury battery and do not feel good with modern 390/ 394/936 1.55V silver oxide. Some of them do, some of them don't. Mine seem to be "over-active" and run too fast when on the wrist.
There are two common solutions: "rephase" which is more "watch repairman" thing and adding a diode in series with the oscillator to lower the voltage by .2V. I'm definitely not going to get into "rephasing" story, but the diode seem to be a good solution that I can do myself. Moreover, there is an commercial semi-official solution called Accucell-1 which is not more then a 395 cell with a diode:
Sure, being an electronic hobbyist, I'm far away from the idea of buying dirt chip diode with same value cell for 15 buck shipped a piece each 7-9 month! The only problem, that I was not able to figure out the diode part number. Not by searching, neither by figuring out what this particular "SW" mean. I believe this is some kind of Schottky diode with 0.2V drop on 10 uA load.
First of all, I'm interested in figuring out the part number of this particular SMD diode used in "official" proved solution. If not.. any suggestions are welcomed.
