( Hopefully this hasn't already been answered on the forums, I had a bit of a search but couldn't find anything. )
Digikey and element14 have heaps of SMD flat flex connectors, but I can't find the actual flat flex cable on their sites -- do they stock them? What's the normal prototyping procedure -- do you buy more than you need and cut it to length yourself, like the way it is with normal cables? If so, how do you prepare the ends?
Basically, somewhere out there has used flat flex in their personal projects, and I want to know how you did it!
Cheers :-)
