As mentioned above, this is probably for two different brightness (ie - backlight power) levels, the 15uH inductor reduces the rms current (though not the average) drawn from the battery at low brightness while the 1.5uH indcutor will, presumably, have lower I²R losses at high brightness/power level.
This still wouldn't make much sense (why not wind use a bigger core for the 15uH inductor and wind it with bigger wire) *except* that this schematic claims to be from the iPhone 6S and so one might surmise that the height of any component would be severely constrained, and in this case it probably works out that 2 inductors take up more board area than 1, but at a lot lower height, and the latter was deemed more important than anything else.
