Hello, I am currently working on a project to replace the NAV headunit in my 2006 Legacy GT with an SBC and 7" touch screen. I would like to utilize some existing signals coming into the headunit plug (like park, ignition, reverse etc) and helpfully I found a service manual that has a pretty complete circuit diagram of the OEM headunit. I will need to shift the level of the signals from 12v to 3.3 and was looking into how best to do that and protect the SBC from transients and whatnot and decided to look into how the Pioneer engineers did it. what I found was variations on the circuit attached. I I was hoping I could get some help deciphering it and if it is worthwhile reproducing it on my project. the components are as follows:
Resistors/caps: obvious
D800: MA3220-H - Zener Diode; Silicon planar type; 22v
D807: DAN202U - Ultra High Speed Switching Diode
Q800: DTA124EUA - digital transistor
Without sounding too much like a novice, I assume the caps are for noise, the resistor is for current limiting and the zener is for voltage spikes? I am not really clear on the last one and am still working out the switching diode. Thanks for any help.
