Author Topic: LCX058AKC + LC98500 - mini 1.4 inch LCD from SONY reverse engineer  (Read 1163 times)
Offline Vector101Topic starter
The purpose of this project is to reutilize the LCX058AKC type of mini LCDs that usually are used in digital cameras.
As the project will progress I will update this page with the information I find.
If anybody would like to lend a hand that would be helpful.
The final target is to use a STM32 or ESP to drive the LCD if possible or find an alternative for the custom LC98500.
LCX058AKC - no datasheet - 1.4 inch LCD
LC98500 aka TPG018A - no datasheet SANYO/PANASONIC Custom ASIC - LCD driver usually drives 2 LCDS main camera pannel or EVF
« Last Edit: February 16, 2018, 09:30:49 pm by Vector101 »
Offline PhillyGreg
Re: LCX058AKC + LC98500 - mini 1.4 inch LCD from SONY reverse engineer
« Reply #1 on: February 17, 2018, 02:28:00 am »
Perhaps, this might be a place to start?
https://www.eevblog.com/forum/projects/drivin'-a-sony-lcd-viewfinder/
Looks like the same part, and the OP attached a datasheet.
No progress made, but the datasheet seems to be complete enough to get it running.
