G'day all, I've always been mostly happy with my cheap ZD-917 desoldering station, (there's a heap of other companies selling the same product in a standalone unit too - desoldering guts are the same), but always thought it could be even better ...... and it can!
Today I finished upgrading mine - there's 2 parts to this upgrade, forcing the pump to always run and adding a tiny electronic air valve inside the handle. Here's some pics I took during the upgrade:
The vacuum tubes aren't a tight fit so i added some silicone and then zip tied the tubes on - they are very airtight now!
I added some silicone to hold the valve in place and prevent it from jumping around inside the casing under load.
yes, it all fits (after breaking out a plastic tab and removing some unneeded rubber jacket from the wiring)
and fully reassembled!
after cutting the wires to the motor, I used a terminal block to wire the motor to always on and wired the gun-switch in parallel so it could steal 12v for the air valve.
NOTE: the motor is wired opposite to how it's marked (-/+ are swapped).
I added some yellow electrical tape to the metal frame as the edges on it are a little sharp and I didn't want the wiring etc getting damaged in the long run.
Just finished testing!
and a bloody good result! this 62 pin header came out out with very little effort! I'd tried to recycle a bunch of these previously (the header is the wrong spec) and ended up destroying the pcb's!
and back in her home ready for more action!
The parts I used are as follows:
So this cost me about $5 AUD I reckon and the performance is dramatically better, Im really blown away by how much better it is, and I was expecting an improvement!
