Hello,
I've just came across interesting problem... Is there any chinese PCB prototyping service, which can deal TFBGA216? The device manual suggests this PCB pattern (see attachment please).
Most China PCB houses can't do smaller than 12mil (0.3mm) holes / 24mil (0.61mm) outer dia. But this seems useless for this kind of a BGA beast. With the proposed dimensions, it seems also there is only 5mil clearance between pad and via.
Can the pcb pattern be somehow altered to fit the chinese manufacturers? What do you suggest? Do you have any experience with these packages and china pcb houses?
Thanx,
Y
