Author Topic: Quick question -- what is this extra device in a 1W white LED package?  (Read 2257 times)
Offline dmacfarlandTopic starter
Hey guys, I was just looking at this generic 1W white LED and noticed a separate device outside of the white die area (lower right in my photo). After some research, I've seen a similar arrangement in Cree LEDs but no mention of what it is in the datasheets.
All three bonding wires you can see coming from the right are on the same terminal and so are at the same potential. The other terminal is blurred out on the left side.
I'm sure it's something obvious but I can't think of what it would be.
Offline Audioguru
Re: Quick question -- what is this extra device in a 1W white LED package?
« Reply #1 on: January 04, 2017, 03:40:05 pm »
It is the mounting base connection. Maybe to allow you to prevent damage from static electricity.
Offline GreggD
« Reply #2 on: January 04, 2017, 04:25:56 pm »
It is a zener diode for ESD.
The following users thanked this post: dmacfarland
« Reply #3 on: January 04, 2017, 04:29:20 pm »
Thanks, that is what it seemed like to me in my rudimentary testing, but I wasn't sure and didn't want to push it too far.
Offline edavid
« Reply #4 on: January 04, 2017, 04:34:22 pm »
Does that mean these LEDs conduct in the reverse direction?  Or is there also a blocking diode?
Offline GreggD
« Reply #5 on: January 04, 2017, 05:51:28 pm »
No blocking diode. Short wavelength leds (blue) are very sensitive to esd. So this zener is across the led, zeners just above the leds normal voltage and clamps at about 0.6v when reverse voltage is applied.
« Reply #6 on: January 04, 2017, 05:57:58 pm »
I was measuring 0.75v, but I was being very ginger with it. In any case, that's pretty much exactly what it looked it :)
