Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Cost effectiveness of conductive ink printing on PTFE
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Cost effectiveness of conductive ink printing on PTFE (Read 1424 times)
SreejitS
Contributor
Country:
on:
February 16, 2017, 09:29:22 am »
Hello all!!
I am working on a project which requires multiple LC-tank circuits on PCB of approximately 40cm x 40cm resonating at 1MHz. I wanted to know whether it is cost effective to go for conductive ink screen printing process on plastic sheet as they do with keyboards. Are there any technical caveats that i should be aware of before jumping into them.
I am talking about circuits like shown below :
http://image.made-in-china.com/43f34j00jZSEFKhywPqH/Keyboard-Flexible-Printed-Printing-FPC-Circuit-Board.jpg
Logged
My favorite place to hang out : FooBar
CM800
Frequent Contributor
Country:
Re: Cost effectiveness of conductive ink printing on PTFE
Reply #1 on:
February 16, 2017, 09:32:26 am »
I'd have some quality concerns, It makes more sense in my mind to etch, you'd get much finer quality.
you can conductively coat nigh-anything, then etch it.
Is there any reason you can't use a standard PCB?
Logged
SreejitS
Contributor
Country:
Reply #2 on:
February 16, 2017, 09:52:51 am »
Quote from: CM800 on February 16, 2017, 09:32:26 am
No, I can use a standard PCB. I want to know if the alternative option is cost effective or not.
Logged
CM800
Country:
Reply #3 on:
February 16, 2017, 10:01:50 am »
I suppose a good question would be how many are you gonna be using per year?
I'd say PCB will be hard to beat, the competition between pcb manufacturers is quite big and the market-base is much larger then any other method.
Logged
Ian.M
Super Contributor
Reply #4 on:
February 16, 2017, 10:16:36 am »
There's two other issues here:
1. Its *VERY* difficult to get anything to stick reliably to a PTFE surface, so the conductive ink is likely to flake off.
2. Conducive inks have a significantly higher resistivity than pure copper or silver, so the tank circuits will have lower Q.
Why would you even want a PTFE substrate at 1MHz? Even SRBP is fine at such a low RF frequency.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
