Just adding my 2 cents worth.
Over many years, I have seen plenty of crimped connections breaking off just behind the crimped part.
These were supposedly "properly crimped with the correct tool", as they were factory jobs.
Automotive ones seem to be the worst, as they don't seem to provide enough support for the wire.
It seems that the clamp which is supposed to crimp around the insulated part of the wire during the process doesn't close tightly enough.
The repair has been to solder the connector, with in every case, a longer resultant life time than the original.
I have also seen crimp connector failure in Broadcast Transmitters & other such equipment.
Again, in many cases, the answer has been replacement with a soldered lug, due to not having the correct tool or lugs, & needing the equipment restored to service ASAP.
Even with the correct tool & crimp connectors, it is sometimes difficult to find enough length of cable to re crimp, as the conductors & insulation have often been "cooked" due to the fault.
Trying to crimp stranded cables which have been over heated is a recipe for disaster, so in some cases, it is necessary to splice a new section of wire in place.
At this point, if it is at all viable, it is best to make up a new cable entirely, with properly crimping & stress relief at both ends.
A good crimp connection is very good indeed, but a bad one is an invitation to trouble.
The thing is, if manufacturers can't get it right, what chance has someone with an "El Cheapo" crimper off the Internet?
