Hi all,
I have a problem with a 32.768 kHz crystal oscillator circuit that's being conformally coated in a vacuum.
It appears that on some devices, the crystal stops working after the coating. *However*, it seems that the "bad" devices "recover", which is extremely wacky to me.
Any thoughts on what could be happening?
Thoughts I've had so far:
* Coating is dielectric; maybe it is affecting the load capacitance
* Crystal is affected by vacuum, and maybe stops working (But aren't they hermetically sealed?). Maybe the conformal coating "locks in" the vacuum / no-op state, and it slowly relaxes once back in atmospheric pressure
* Coating has some sort of charge attached to it
* Vacuum is causing crystal package to be stressed in some way
Any ideas? This is just a basic 32k crystal, glass top plastic casing... The conformal coating is some sort of proprietary stuff that I don't know much about, but isn't conductive.
-Stewart
