Hi coppice.
5% would be great, this isn't for metering purposes. I was going to try to achieve a kelvin attachment as best as I could as well.
I was originally looking at using CTs but the shunt resistor approach seemed lower cost, less space and less manual complexity to assemble.
At this point I'm most concerned that the smd shunt causes me to redirect the current across one layer of the PCB and could impact the current carrying capability. The rest of the components on the high current path are through hole and connect to top and bottom layers. I found some THT shunts but their resistance is lower and at peak current I was worried about dissipation. It's 30A @ 240VAC, maybe my calculations are broken. I was using a peak voltage of something like 400V, so 400V * 30A, to calculate power through these shunt resistors but its 240VAC RMS so maybe that calculation is indicating far more power than will actually be dissipated and could let me use one of those THT shunt resistors at 0.001 ohms.
Chris
