Hi
I bought some of these:
"DC Buck Step Down Converter DC 5A Regulator Voltage Current Adjustable DE"
http://www.ebay.com/itm/400714751657?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT(just a random picked seller)
Here are the specs and I have questions on what some of the specs mean:
Module Properties: non-isolated step-down module (BUCK)
-- what does non-isolated mean in this case ? Is it the neg of the input is directly connected to the output ?
-- I will look up "BUCK"
Input voltage: 4-38V
-- ok I will be using a 19 v laptop power supply
Output voltage:1.25-36V continuously adjustable
-- good this is what I want (I think) SO if I want say 3.3, 5.0, 9.0, 12.0 volts - I would use 4 of these and set them to the correct voltage ? And one for a variable range ie 5 (bummer I ordered 4)
Output current :0-5A Adjustable (recommended for use within 4.5A)
-- they advertize 5 amp but warn 4.5 a BUT what do you think the real amps are based on the components
Output power: recommended for use in below 75W, more than 50W please add heat sink. (Heat sink not included)
-- how to add a heat sink and I assume it would go on the chip that is laying flat on the circuit board
-- so using 4.5 amps and 50 w as limiting factors here is what I come up with
3.3 volts at 4.5 amps --> P=IE P = 14.9 watts < 50 watts so set I to 4.5 amps at 3.3 volts
5.0 volts at 4.5 amps --> P=IE P = 22.5 watts < 50 w so set I to 4.5 amps at 5.0 volts
9.0 volts at 4.5 amps --> P = 40.5 so set I to 4.5 amps at 9 volts
12 volts at 4.5 amps --> P = 54 watts > 50 watts
close but I would de-rate this to 4 amps. I think with this kind of module you absolutely cannot go over. If fact if I wanted to use 4 amps I would do a lot of testing on this. So I think I would rate this 3 amps at 12 volts
Am I correct in these calculations ?
I would probably change these numbers based on testing and temps of the components
Working temperature: -40 to +85 degrees
-- ok
Operating Frequency: 180KHz
-- no idea what this means on a DC circuit
Conversion efficiency: up to 96%
-- ok
Load regulation: S (I) ? 0.8%
-- I do not know what this means
Voltage Regulation: S (u) ? 0.8%
-- I know what voltage regulation is but I do not know what S (u) ? 0.8% means
Short-circuit protection: Yes (the limited current is 8A)
-- I know what short circuit protection means but not "the limited current is 8A" Does this mean no matter what happens it shuts down at 8 amps ? ie when a short circuit gets to 8 amps it shuts off ? AND anything else that makes it get to 8 amps
So if I had a 5 v circuit that started to draw 8 amps it would shut down?
Over-temperature protection: Yes (automatic shutdown when over-temperature)
-- ok but what temp ? could I test this by making it get hot and check the temps.
Input reverse polarity protection: No, (if necessary, please string into the high current diode)
-- interesting I think with my adapters this would not happen but how to add a high current diode ? Sounds like an expensive component
Installation: four 3mm screws
-- I assume 3 mm holes
-- How could I failure test these ? At $4 each I think I could failure test 10 units.
-- Is there anyway to find a schematic? Would I have to reverse engineer it to come up with a schematic ?
I would appreciate a testing protocol
thanks
Roger
