Thanks for all of the input everyone.
Got sidetracked working on the power supply board that will go with this one. Wanted to get it done before the free shipping deal was over.
I was over in another thread talking about bringing up a Zynq board with DDR3x16 - as of today I have what seems to be a working design for 4-layer boards.
Thats awesome to know, I've been reading a lot of 8 layer recommendations, and haven't had the time to really look at the pinout yet.
However after running IBIS sims even with grossly out-of-spec traces, I realised that ODT will take care even of most extreme cases for writes, and similarly FPGA side's IN_TERM is pretty good at ensuring good SI for reads.
Good to know on the clock, worth adding a couple spots for resistors to be safe.
I've read so many datasheets and tech notes, I'd forgotten the 50Ohm was for the low speeds. Thanks for the reminder.
Sounds like ORCAD is a pretty sweet package, I've been eying the deal that I've seen advertised...but not the best time of year to be buying more software.
I did spend some time with Altium this weekend, I know everyone pretty universally feels that it's SI tools are useless.
I agree UI wise they absolutely suck. And it can't use ebd models for the SODIMM.
I figure if they have it in the software, it can't be absolutely wrong. Not as refined, accurate, or misleading I can believe.
(Now if it can't properly model a square wave, a transmission line, and a termination...I'm very concerned about the rest of the program as a whole.)
I threw together a quick schematic with 4 x8 DDR3 chips with both spec and out of spec traces and what I saw matches your description.
Out of spec traces do have an effect, and at over 1066 it is rather dramatic on the Addr/Control lines, but not nearly as bad as I was expecting to see.
The reduced strength is a great tip, that may do the trick.
Given this, I may just finish off the SODIMM layout I've mostly finished. ALLPCB's calculator is showing like $60 and free shipping.
Since I've never done an Artix layout, I'm thinking keep it super cheap with the smallest Artix.
Spend the holidays thrashing it and get it right the first go with ourPCB.
