The power is 960W, I'm looking at different chips at LT demo circuits.
I am new to designing a converter any help or advice would be much appreciated.
960W is quite a lot of power. For example, that's going to be like 100A at the input (considering efficiency and a 10V input). I think that you should warm up on some smaller stuff first.
Regarding topologyI totally agree with David Hess and rx8pilot that a multi-phase solution would be required. Multi-phase is very much like 'strapping some smaller ones together,' only you need a little extra circuitry so that they all synchronise with each other.
In addition, you will need external MOSFETs (perhaps several in parallel) and synchronous rectification. Something like the
LT3784 might be a possibility. Check out page 34 for a 24V 20A circuit. It's a 4 phase interleaved synchronous buck converter.
Some numbersAs a quick ballpark for the 24V 20A circuit, you would aim for 95% or higher efficiency, so the total losses would be somewhere around (480/95% - 480)=(505 - 480)=25W. Assuming that around 1/3 goes to inductor losses and 2/3 to the MOSFETs, we see that (50*2/3)=16W is spread over 8 MOSFETs, yielding (
very roughly) 2W per MOSFET.
The HAT2169H has a thermal resistance to the PCB of 4.2 C/W. With a big exposed pad on the PCB we might be able to hit ~ 30 C/W from PCB to air. So thats ~ 34C/W * 2W = 68C temperature rise. With a 50C ambient temperature, we get silicone junction temperature Tj = 50 + 68 = 118 C, which looks OK. However, the PCB could be around 50C + 30C/W*2W = 110C, which is perhaps too hot for long term reliability.
So if you double the circuit from the LTC3785 data sheet to have 4 phases, you might get your 960W output. Total losses would be 55W or so, which is manageable with care, a fan, and a somewhat special PCB.
