Hi:
Nice design. I'm new in electronics. since you made this design may be you can steer me in the right direction. I Have a old Condor Power supply from 1990 I suppose. Its old and came out out of a Stress Test ECG machine.. The PS works fine. It puts out +5 at 10amps ; +12v at 3amps ; -12v at 3 amp ; +15v at 3 amp; +28v at 1.25 amps ; -28v 1.25 amps, I would like to regulate the voltage between 1.2 to 30 volts and be able to control the current output maybe from 10 um to 1.10 amps on the plus and minus of the 28 volts output of PS. On the 12 volt and 5 volt side output I would like to control the current output from 10 um to 1.5 amps so I don't burn out any of my components when testing on the bread board... I very prone to shorts. If you have any solution simple for my problem. please I will appreciate the help. Thanks Ricardo
